Commandline not working with Dragon software
Due to an injury, I need to use Dragon software to utilize auto CAD. For whatever reason, the voice recognition will not activate commandline. Can anyone help me with this. Stop working about a week ago. Thanks
john.vellek
HI @Anonymous,
Have you tried contacting support from Dragon (Nuance Communications)?  They probably have a better idea of what might be going on. Can you get Dragon to bring focus with the command line? For instance, when you ask Dragon to enter a command in the command line do you see any text entered at all?
John Vellek
Please provide additional information -
Which DNS software program and what version of the software are you using?
Did you recently upgrade/update?
Is the command line visible?
Is the problem with all of your commands or just with some?
Is your microphone working correctly?
Is background noise an issue?
MarkFitz
I'm having the same issue, my Dragon software is brand new.
Should I contact Dragon first?
I did experience a noticeable pause when trying to click outside of Dragon while in AutoCAD. Do the two not play together well...?
Mark
Does Dragon work at all with any programs? I am using Dragon Professional version 15 and it is working fine with Autocad 2019
MarkFitz
Yes, the Dragon professional individual v15 works with all my other programs except AutoCAD 2019, you know the one I spend 90% of my time using. What setup do you have that allows it to work? I was told by Dragon tech support that the two are not compatible. If you got it working for you, please tell me how to do it, are there any settings I need to adjust?
Mark
MarkFitz
And to what degree does it work for you, are you able to speak commands or just dictate text?
