Command modifiers - suppress dialog box?
Hello.
There is a symbol or something that you type in the command line before a command which normally would open a dialog box to suppress its dialog for that command only.   I stumbled upon it once upon a time when reading through a LISP program someone had wrote and I remember thinking it would be very useful.   But now a year later I have forgotten it.
For example, the normal command might be
SAVEAS
And if you type __SAVEAS or $SAVEAS or .SAVE as or ~SAVEAS or something like that it will suppress the dialog and allow you to enter your options on the command line.    Its very useful for scripting.
But I cant remember what symbol it is and I have tried all of the above and none of them are it.
Who knows what I am talking about?
cadffm
For Scripting only Attdia(and attreq) for attributvalues.
Sometimes cmddia.
Script(menumacro and sendcommands) starts always the commandlineversion of a command, if available.
For working by hand in commandline the commandline versions starts with "-"
WBLOCK
-WBLOCK
LAYER
-LAYER
But as i wrote, menumacro script and commandline start this commandlineversions.
You send command LAYER and Autocad will start -LAYER
For testing in commandline by hand, you have to set filedia=0 for file selection dialogs and you have to start -LAYER and not LAYER for example (for checking the options and the workflow)
Sebastian
david.burow
I know this is old but it was the top hit on google and didn't have what I was looking for.  I ususally use the - for command line, but I've seen scripts that use this format:
_.wblock
_.layer
I don't know what the difference is, maybe someone more knowledgeable can advise.
cadffm
One part of the answer you can read above.
LAYER command for exampe is a command with a dialogwindow(or palette),
-LAYER command is a command without a dialog window (or palette).
If you starting LAYER command in a script macro or (send)command, AutoCAD know it and starts the -LAYER command.
If you want to start this command by hand, you need to use -LAYER instead of LAYER.
In Script Macros and (send)commands always the -LAYER command will stsrt.
Underline or not.
LINE is an english command, which will not work in french or german versions.
_LINE is the international command, this will works in all language versions.
.LINE starts the real native LINE command.
Real Native ?
Yes. Programmers can make that LINE command will create a circle or line on another layer than the current one.
.LINE will start the original line command.
_.-WBLOCK
Will start the original  -WBLOCK command (the commandline version of WBLOCK) and is wotrking in all language versions.
Sebastian
