Command list showing commands from workspace
lbellino4
lbellino4
Hello.
I'm trying to help a fellow associate with this issue. He reinstalled his AutoCAD 2025 and upon doing so, somehow in his command list in the section I circled below, it shows all the commands that are part of his custom workspace. How does he remove them or does he need to uninstall and reinstall his AutoCAD again? The image example shown below is from my AutoCAD and doesn't list commands from my custom workspace. Thanks in advance for your help.
vladimir_michl
This is a list of all commands defined in the loaded CUIx menus - what's wrong with having additional commands there?
Vladimir Michl, www.arkance.world  -  www.cadforum.cz
lbellino4
Well, he doesn't want them in this list, plus why were they added? The custom workspace I work in, in my AutoCAD 2025 doesn't list these. I'm just curious if there is a way to remove them or just turn them off, if they can't be removed.
vladimir_michl
If you unload your custom CUIx files, they will disappear.
lbellino4
Ok, so I have two questions about this. How do I do this? And once this is done, will the custom workspace(s) still be available like I have shown below? As you can see on my AutoCAD, I'm still able to use my workspaces I created, but as you can see the commands are not listed in the command list below it.
pendean
Community Legend
Community Legend
@lbellino4 wrote:
Ok, so I have two questions about this. How do I do this? And once this is done, will the custom workspace(s) still be available like I have shown below?...
CUIUNLOAD command
But... if you want access to them occasionally but not all the time then you all need to get into creating and using multiple AutoCAD PROFILEs: one with and one without those add-ins. You can look that up in HELP.
May I ask: why the need or a reinstall and why is this all new to the same exact user? How did they doo all of this before the reinstall? There might be something worth recovering and recreating, but we over here cannot help you with that, someone at your end created it all initially.
Best wishes.
lbellino4
My associate mentioned that this was never there prior to the reinstall of AutoCAD 2025 and wanted these extra commands from his workspace removed from the list. But by the time I got everyone's input, he already uninstalled and reinstalled AutoCAD again, which fixed the problem, but this is helpful if this happens again and he wants them removed from the command list. Appreciate your help!
