Command Line Text Alignment
edg76
Observer Observer
edg76
Observer
Observer
Hi everyone, for some time now the command line text has been aligned to the right and no longer to the left as per the attached images.
The problem was present in autocad 2021 and I thought about installing 2022 thinking it would be solved, but unfortunately it is always present.
pendean
Community Legend
Community Legend
A test: expand your commandline to show 3-4-5 lines, repeat your entries, and post a screenshot of that please.
edg76
Observer
Observer
edg76
Observer
Observer
Here, I took the screenshot as requested ... Small update ... To try to solve the problem I uninstalled autocad 2021 and installed the 2022 but the problem persists and the strange thing is that this text alignment problem is there I also have on another pc that has the same characteristics as this main one and even there the problem remained even after installing autocad 2022. Since on a third pc that has the same account both microsoft and autodesk the problem is not there for me the question arose that the problem could be caused by the fact that on the first two I have an AMD threadripper 3960x architecture, while the third pc is intel, could this be causing the problem?Senza titolo-1.jpg
pendean
Community Legend
Community Legend
Dock your commandline, then start a support ticket through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
