Command Line string
Command Line string
orders3
Message 1 of 11
Command Line string
orders3
I am trying to paste a string in the command line.  The following use to work.
Now it sets the cursor position, text size, rotation angle.
Then waits for me to manually enter text.  I want it to past "My Text Here".
-Text 3.5068380277659,43.3146116396603 1.5 82.4077777777778 My Text Here
What has changed???
Accepted solutions (3)
Replies (10)
Message 2 of 11
Tomislav.Golubovic
Just tested it manually and it worked, only thing I can think of is you need to put another carriage return at the end? Is this in a script or you just put it in manually?
Message 3 of 11
orders3
I paste it in the command line.
Message 4 of 11
Tomislav.Golubovic
So it doesn't put the text in? Or it does and it just waits for you to press enter?
Message 5 of 11
orders3
Script Entered          _Text 3.5,6.2 15 82.40 My Text Here
I paste the above script in the command line. Hit Enter
(This appears)
 Command: _Text
Specify start point of text or [Justify/Style]: 3.5,6.2
Height of text <15.0000>: 15
Rotation angle of text <82>: 82.40
(It's waiting and I enter some text 1234,etc) and  Enter key twice. 1234 appears on screen
(This appears)
Command:
_TEXT
Specify start point of text or [Justify/Style]: My
A point is needed. Please try again:
Specify start point of text or [Justify/Style]: Text
Specify start point of text or [Justify/Style]: Here
(Thanks, but I'm on east coast time, so bed time) - More Tomorrow)
Message 6 of 11
paullimapa
You originally stated that you preceded the TEXT command with a hyphen: -TEXT
Now your new example shows that you are preceding the TEXT command with an underscore: _TEXT
Try what you had originally posted by copy and pasting using a hyphen to precede the TEXT command and not an underscore:
-Text 3.5,6.2 15 82.40 My Text Here
I had to do a ZOOM Extents afterwards and then I saw My Text Here:
Paul Li
IT Specialist
@The Office
Message 7 of 11
cadffm
>>"What has changed???"
Nothing
>>"Then waits for me to manually enter text."
If you forget to copy the linebreak ro enter your textvalue, sure.
>>" I want it to past "My Text Here"."
It's already done (if your textstyle has height >0), or already paste in the commandline (but not send)
>>"(This appears)"
That's another command. Don't switch to another one during one and the same topic, without pointing to
-TEXT is the command you wrote about and which you should use.
Sebastian
Message 8 of 11
pendean
Community Legend
Community Legend
@orders3
Dash, not underscore, seems to work 100% of the time (plus an extra "return" after your words), so...
Message 9 of 11
orders3
Thanks - You are correct. Tried on different machine and it does work with a hyphen.
Perhaps need to reinstall ACAD.
Message 10 of 11
orders3
Perhaps need to reinstall AutoCAD.
Message 11 of 11
paullimapa
So are you saying even with the hyphen the text command doesn’t work on your machine only?
Instead of uninstalling try resetting your AutoCAD
How to reset AutoCAD to defaults
Paul Li
IT Specialist
@The Office
