Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Command line length follow up problem
mcgann001
mcgann001
Hi, posted a command line length post a few days ago and my problem was solved by vinodkl, thanks.
I have a new CL window problem. I got my command line window the right width and moved it over to the left side (see command line 2 image). Set my lockui to 15 and it stayed. A few minutes later it moves to the right and locks itself to the middle bottom of the screen (see command line image 1). I have to unlock it (lockui set to zero), move it back to the left and it moves to the middle a few commands later and stays lock again.
Thanks for any help.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @mcgann001,
That is an interesting one that I have not seen before. I did find this Autodesk Knowledge Network article that mentions the command line not being able to over lap other elements. From the screen shot you provided, it looks like this may be the case.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/comman...
Do you see the same issue if you move the locked position of the command line off the Toolbar pane?
Click the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
