Hi.
I have Civil 3D 2015.
When I have some opened drawing files, in the current drawing file I can´t type in the command line. The command line appears in color gray.
If I change the current drawing, then all I typed before appears in the command line.
I think it´s some trouble with the database of the current drawing which not recognize properly the current drawing.
To solve this, I have to close all the drawings except one.
What could it be the solution?
Thanks in advance.
Solved by sthompson1021. Go to Solution.
No solution for you, but to let you know your not alone.
I have found recently that the command line in C3D periodically stops working and I think I have found the reason. It always happens when I have 2 or more drawings open and the crazy thing is that the command line is deactivated in the active drawing but is activated in one that is not active. If I sort through the open but not active drawings, I find the one that has my commands in the field and hit escape, then go back to my active drawing and it works again. Whats causing this? CAD has not behaved this way until fairly recently. I have also noticed that after a command finishes, CAD is stuck until I pan. I used to be able to free everything up with the escape key but now I have to pan then hit escape???
