Hi All,
Please give me the solution for copyclip Appearing appearing always while working fast.
It's annoying.
Please view the attached video reference.
Solved by smrifas. Go to Solution.
Solved by vinodkl. Go to Solution.
Does this happen in all drawings even when you create a new one from scratch ?
Try close and open the file again, if it is the file try copying the data to a new drawing.
Did you try restarting the Autocad application.
If its happening for all of your files then I suggest you to reset the Autocad to default.
Cheers,
Vinay Vijayakumaran
Hi @smrifas
See if this helps: https://www.cadtutor.net/forum/topic/17583-problem-with-copyclip/
Thanks.
Got Answer/reason by https://www.cadtutor.net/forum/topic/17583-problem-with-copyclip/
"I had the same problem and it was due to an installation of «client for google translate». Just disable that client with right mouse clic on the icon in the task bar !"
