Command Alias Question
lbellino4
lbellino4
Hello.
I had to reset all my command aliases because I had to restore my ACAD to its default settings. Luckily, I saved a copy of my edited PGP file to reference for the key commands I use frequently and was able to import. Was having issues with all of them working because they were still referring to their original default, but after reading other comments, I made sure the corrected pgp file was being referenced in the support file path. For the most part, I tested a few commands I typically use and they are working...for now, except the one I changed for the "OPEN" command.  I've already closed out of ACAD and reopened and this didn't fix the issue.
Is there a reason why I can't get my command for "OPEN" to work when I type "O" as I've shown in the images attached? It still brings up the OFFSET command. Any help is much appreciated.
I'm working in AutoCAD 2019
Windows 7 Pro
Patchy
(findfile "acad.pgp")
Copy and paste this line in your command line then hit enter,
see what being loaded.
lbellino4
Thanks for this...it worked! Smiley Happy What's weird is that it had a saved day and time of earlier today when I was editing. Not sure why this particular command didn't work through the alias command and I had to manually add to this file. I'm sure I'll have to reference this post again, since my autoCAD always needs to be reset to defaults a few times a year.
scot-65
Perhaps keep an eye at the bottom, inside the PGP file.
AutoCAD suggests this is the place to define your keys.
Last definition wins...
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
r.bradshaw
Community Visitor
Community Visitor
Thank you for the help on this issue as well.
