Combining Surfaces
Combining Surfaces
No aplicable
I have a solid terrain created by contours. The top surface of solid is collection +500 small surfaces. I do need to combine all top surfaces and make them as one surface to be able to create a mesh in another pre-processor for meshing procedure. Can anyone help me out please?. The file is attached in case you wanna look at it. Thank you.
Muhsin
0 Me gusta
Responder
Soluciones aceptadas (1)
8.719 Vistas
31 Respuestas
Respuestas (31)
Alfred.NESWADBA
one possible workflow:
  • delete the 3D-Faces, so only the 3D-Solid remains.
  • you can now use command _CONVTOSURFACE
  • another option is command _CONVTOSURFACE, but that creates many objects (area-by-area) which then need to be joined using command _UNION.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
SEANT61
This may or may not help.  The solid was sliced via lofted surface, and may not work well with downstream processing either.
May your cursor always snap to the location intended.
0 Me gusta
No aplicable
Dear @Alfred.NESWADBA,
I have converted the solid to surfaces using _CONVTOSURFACE. Because the top surface of solid had many small surfaces, I exploded top surface and tried combine them. Unfortunately, I failed. How can I union the exploded surfaces ?  the file is attached.Thank you.
Muhsin
0 Me gusta
Alfred.NESWADBA
Which message did you receive from AutoCAD, by default it shows you one or more reasons about what happened.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
I was using Union function, assuming it may work for surfaces. It took around 10 min to recover itself. but nothing happened to top surfaces.
0 Me gusta
Alfred.NESWADBA
Yep, it works for surfaces, but not for (none coplanar) region objects. And your second drawing only contains regions, no surfaces.
So I guess _EXPLODE is not an options.
And I'm quite sure you have got a message back from AutoCAD:
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Yes, I had that warning in the prompt. So, I have no idea how to merge those surfaces. What would u suggest me in that case ?
Thank you.
Muhsin
0 Me gusta
Alfred.NESWADBA
At least not using _EXPLODE.
Or when you want to start with the region objects you can use command _MESHOPTIONS to convert the regions to meshes, then run command _UNION and convert the meshes to surfaces.
But it's hard to say what would be the best for your workflow as I don't know your goal (and have not understood it from the other thread where I created that solid).
- alfred -
Alfred NESWADBA
0 Me gusta
Alfred.NESWADBA
please find attached the result of the alternative workflow mentioned in my previous post.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
My goal is to having  a solid that has one single surface at the top and 5 at the sides and bottom. I am going to transfer that solid to FEM software. In this case I cannot work with this solid because small small surfaces causes problem with meshing process in FEM software. Sorry for misunderstanding. Unfortunately, The surface you created in the last attach is still having small surfaces at the top.  Thank you
Muhsin
0 Me gusta
Alfred.NESWADBA
Well, your first drawing in your post has such a 3D-Solid.
So you need to reduce the quality from the triangulated 3D-Solid ... but this triangulation was based on your contour lines.
So the way to go is back to Civil 3D, create a surface based on your contour lines, then reduce the quality (which tolerances are given for that process?)
After that recreate the 3D-Solid from the Civil 3D surface.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
I need that topography to place the structure on.  I have used 80x80 spacing for the current file to from the surface. Wouldn't reducing the quality give the collection of triangular surfaces again? Thank you.
Muhsin
0 Me gusta
Alfred.NESWADBA
Working with Civil 3D always generates surfaces based on triangles.
Does your FEM-software only work with rectangle based faces?
Is the limitation the size of the triangles or the number of the triangles?
At least reducing the number of geometry will reduce the quality (as long as you don't have neighbored faces with the same slope ... they can be combined to one face without losing quality)
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
I am going to try to reduce the quality. But can you please tell me how I do combine the top surfaces to one surface? That's the killing part I guess. Thanks
Muhsin
0 Me gusta
SEANT61
What happens when you try to use the solid that I attached in Post #3 of this thread?
0 Me gusta
No aplicable
Deat @SEANT61;
I am so sorry I just realised you have attached a file to this thread. I looked at it now and I could successfully transfer the solid to FEM software with single a single top surface. I appreciate it. Can you please explain a little bit more what you have done to the solid ?  Thank you.
Muhsin
0 Me gusta
SEANT61
I’m working on an AutoCAD add-in that processes contours at elevation into a rectangular lofted surface.  I used that surface to Slice a solid to produce the solid you see in that file.
0 Me gusta
No aplicable
Dear @SEANT61,
I am sorry but I am having difficulty to understand what you have done. It might because I am not a native speaker. Can you please rephrase the steps you have done? I spent lots of time to solve this problem but couldn't. Thank you.
Muhsin
0 Me gusta
SEANT61
Similar to the process that creates a surface with Civil 3D, I'm using a command that is not native to AutoCAD.  The command analyzes contours and recreates the surface via a rectangular lofted surface.  The attached is the intermediate step, before using the surface to slice a solid as I did in my first attachment.
