Anuncios
Combining object into single solid object
No aplicable
Hi
i have broken one object which was single using explode command, But after editing some part of it i am not able to export it to STL format. So i need to re-combine all the poly lines to one object and then i can export to STL Format.
I have attached .dwg file and also screenshot. I am unable to use join command it gives me error. 36 object discarded from operations 0 objects joined.
0 Me gusta
Responder
Soluciones aceptadas (1)
6.675 Vistas
6 Respuestas
Respuestas (6)
Patchy
Autocad can't make STL from polylines, only 3dsolid can be STLOUT
0 Me gusta
No aplicable
I want to do the same. I have exploded the object but i am unable to make it 1 single piece solid again, so i am unable to export it to .STL format.
Please help me with joining this multiple exploded objects. I use group command but it doesn't make single solid object. its not working either.
Please hep.
0 Me gusta
No aplicable
@Anonymous wrote:
Hi
Seems like it'll be easier to just recreate it than to mess with all of the regions and surfaces you created by exploding the original object.
0 Me gusta
Patchy
Save your dwg to 2007 and attach it for me, let see what you have.
0 Me gusta
No aplicable
Hi
Please find attached DWG File in 2007 Format.
0 Me gusta
Patchy
Solución aceptada
Explode 3d in autocad is not good.
Use PRESSPULL or LOFT command on the red part, then move your parts together, use UNION command then STLOUT.
