Combine Multiple Mtext into 1 Mtext
Message 1 of 27
Does anyone have a tool to combine multiple pieces of Mtext into a single
Mtext with paragraphs?
Replies (26)
Message 21 of 27
The routine is very handy for me when I come acorss dwgs where someone made seperate mtext paragraphs. Thank you so much for witing this routine.
Message 22 of 27
Just found this routine after a short search, does exactly what I was after.  My complements to Kent Cooper, nicely done.
Lan
Message 23 of 27
troma
Lovely tool @Kent1Cooper
I went and marked your post as the solution.
(BTW it was a Google search, not a forum search that brought me here.)
Mark Green
Working on Civil 3D in Canada
Message 24 of 27
An easy way is to explode ("EXPLODE") all the mtexts, and then use the Express Tool command "TXT2MTXT." You can click "yes" or "no" to adding a return after each line.
Message 25 of 27
yjavadidoodran
Community Visitor
Community Visitor
I just had this question and noticed that in AutoCAD 2022 you can easily select all txt objects and convert them to MText using the command TXT2MTEXT all all txt objects will be combined to one mtxt
Message 26 of 27
eric_hailar5FPJN
Community Visitor
Community Visitor
explode the different lines of mtext and it will convert them to text then use txt2mtxt command
Message 27 of 27
pendean
Community Legend
Community Legend
@eric_hailar5FPJN wrote:
explode the different lines of mtext ...
You've not had to explode separate mtext first just to join multiple mtext (or combo of mtext and text) together into one in quite some time now
Unless you use a very old AutoCAD that relies of a very old Express Tool, but then there are free LISP that get around that limitation for your old version.
HTH
