Anuncios
color of solid to black
coolkris
coolkris
Dear all,
As per attached image I want to change the color of solid or face of solid to just black .
Whenever I select white color it remains white. I beleive there is no black applied to object as the screen back ground is black. Still There is some vaiable that will change the color of the object to black.
Krish
0 Me gusta
Responder
Soluciones aceptadas (1)
663 Vistas
1 Respuesta
Respuesta (1)
vinodkl
Solución aceptada
Hi @coolkris
You can choose the color 0,0,0 which is black. Note that by changing the color of the object to 0,0,0 assuming you are having a black background, it would be difficult to see the object and select it in order to modify it. It would be better to change the background color to white and then turn the object color to 0,0,0 and work on it :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
