co- ordinates
co- ordinates
No aplicable
Untitled.pngWhile using slice tool, even though i entered the right co-ordinates, it doesn't specify the second and third point for slicing.  what could be the issue?
0 Me gusta
Responder
Soluciones aceptadas (1)
866 Vistas
11 Respuestas
Respuestas (11)
Alfred.NESWADBA
From what I see in the screenshot AutoCAD is waiting for the third point ...
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
No aplicable
No sir, its not specifying the 2nd point?. you can see the co-ordinates in the screenshot.
0 Me gusta
Alfred.NESWADBA
But I don't have your file to know where these coordinates are in the model.
What happens when you type in the third point (you need it anyway)
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
It is not specifying the third point also. With the co-ordinates i entered the second point should be in the place where cursor is in the screenshot but it indicates only the end point of the line.
0 Me gusta
Alfred.NESWADBA
please upload the dwg-file and the 3 points you'd like to enter specifying the slicing plane.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
0, 16.3, 7.5.
0, 5, 30
22.5, 13.5, 30.
0 Me gusta
Kent1Cooper
That's because your image indicates that you have 3D Object Snap turned on.
Kent Cooper, AIA
0 Me gusta
No aplicable
Now turned it off and tried. It shows"2D point or option keyword required".
0 Me gusta
Alfred.NESWADBA
Solución aceptada
object snap or 3D-object snap should not influence the result ... except you have set this option to not default:
Start command _OPTIONS, tab "User Preferences" and make sure the marked settings is the same as in the screenshot:
You can look to my video here, it shows that using your 3 points with your drawing works well.
I don't know why you think that a point - when you entered the coordinate - is not used by AutoCAD.
- alfred -
Alfred NESWADBA
0 Me gusta
s.borello
Ran a test as
0 Me gusta
No aplicable
It worked. thanks.
0 Me gusta
