Co-ordinate Table Lisp
I just wanted to know if can anyone have and share a lisp for co-ordinate in the cad.
I'm after a lisp which allows me to pick points in CAD which then outputs the northern and eastern co-ordinate in a form of a table. Also the points I click on it is also produces a marker 1, 2, 3 etc
I have listed a very specific lisp but if there is anything similar it would help out.
imadHabash
HI,
you may try these two vlx files :
Click2OO - copy coordinates of clicked points to OpenOffice/StarOffice Calc
Click2XLS/Text2XLS - export clicked point coordinates or picked texts to Excel sheets
visit and download from( http://www.cadforum.cz/cadforum_en/download.asp?file=coordinate&sort= )
Good Luck..
Imad Habash
3wood
To put coordinate in the block attribute, you don't need any special lisp. Just use FIELD.
But you need an add-in to change marker number automatically when you insert the block.
Here attached an example file contains a block which has a sequence number and a coordinate attribute.
You can use INNB to insert this block and change the markers automatically (you can start from a number format such as 001). It will put block insertion point into the coordinate field. You need REGEN once to update all coordinate field values.
You can also redefine the block in the example drawing to suit your needs.
Then you can export the attributes into a txt file with ATTOUT command.
Open the file in MS Excel and sort it by marker numers. Result as below.You can insert it back to AutoCAD.
The website doesnt seem to load and when it does load I can not download the files as the websites times out.
Would you be able to attached the actual file with your reply pleasE?
