Closed shape only extruding suraces
Hi,  I'm trying to extrude this shape to a thickness of 2.4mm. I have concerted to poly line and spline, i have tried press pull and extrude faces but each time it will not extrude as a full solid.
Can anyone tell me where I'm going wrong?
Alfred.NESWADBA
>> Closed shape
Sorry, not closed ...
Also control vertizes from 78 to 79 to 80 results in self intersection.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Oh thanks! I've changed it to yes so the shape should be closed now but is still only extruding walls? Any tips?
Alfred.NESWADBA
please upload this corrected dwg-file.
- alfred -
Alfred NESWADBA
Here it is...
Alfred.NESWADBA
vertex 78 to 80 result again as self-intersection, that is not solved in the last dwg-file.
You might try command _FLATTEN which creates then a polyline from that spline segments, this can then be extruded.
- alfred -
Alfred NESWADBA
