Close Block Editor - command tweak
I have an issue which has been noted that after closing the block editor Autocad runs very slowly, the solution to speed it back up is to perform a zoom extents.
I therefore had the brainwave to edit the 'close block editor' command to add 'zoom extents', then 'zoom previous' (simply added ' Z E Z P ) to the command. It seemed to work really well, untill i realised the box that pops up when you close the editor asking 'save' or 'discard changes' no longer pops up, it only requests it at the command line.
Anyway I can have both added command and the pop up box?
scottwilcox1989
adding
(setvar "filedia" 1)
should do it.
Scott
Scott Wilcox, Edmonton, Alberta, Canada
AutoCAD 2014 Professional
Victoria.Studley
Hi @Anonymous,
Thank you for posting your question here. Did @scottwilcox1989's suggestion help you resolve the issue, or do you still need help with this?
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Hi, where would this sit in the macro?
its currently :
^C^C_BCLOSE Z E Z P
adding it like so:
^C^C_BCLOSE Z E Z P setvar "filedia" 1
 or
^C^Csetvar "filedia" 1 _BCLOSE Z E Z P
or still gives the command line request for the save/discard.
Can anyone else help/advise?
