Close Attribute Box with keyboard/shortcut?
humbertolopezholguin
Is there a way to close the attribute box with the keyboard instead of having to click the "OK" button with the mouse?
This question was asked before in 2006 but does not have a resolution.
Close Attribute Box - Autodesk Community - AutoCAD
Also, I know about the "Tab" option. At the moment, I have to click the "OK" button because cycling through by tabbing would take a while with all the attributes on this block.
pendean
Community Legend
Community Legend
No option except as you don't want to do it.
If you don't want the pop-up box in the first place... just hold the CTRL key down while you double-click on an attribute to edit in your block.
That is unfortunate. I did not know about the "CTRL" option. Thank you.
