Clipping Boundary for elements in the drawing
joantopo
Mentor Mentor
joantopo
Hi.
The Xclip command is basically for RefX but I was wondering if there is another command, using a Clipping Boundary to hide the outside of the boundary I mean, elements (circles, polylines,..) in the drawing.
For example, MicroStation has the "Clip Volume" and can do this, also for RefX and blocks (cells) in the same routine.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
tramber
You can also use _XCLIP on block insertions. But not on the model space itself.
There is also a function named _WIPEOUT that draws a blank image covering all what was drawn previously. But you won't be able to make outer. Just an inner. You won't be able to reverse it, as you can do with an xclip.
dbroad
Non-destructive AutoCAD options:
1)Use a viewport (in a layout) to do the view clipping.
2)Nest objects in a block and clip that block. (Copy/pasteasblock)
3)Save the objects to an external drawing, xattach and clip that.
4)Use a specially drawn, self intersecting polyline and convert it to a wipeout. Think how to connnect the inner and outer frames with segments to and from.
5)Draw the outline and clip each block separately.  Doesn't work with non-block/xref entities.
Destructive AutoCAD option:
1)Draw the outline as a polyline and use xtrim.  Doesn't work with blocks.
Architect, Registered NC, VA, SC, & GA.
Kent1Cooper
You can make a Wipeout with a "hole" in it, with a closed Polyline like this -- the left side shows the concept of it, but actually make its wrap-around ends meet each other as in the right side:
Use the Polyline option in WIPEOUT to turn it into one.
And of course, neither the inside "reveal" area nor the outer perimeter needs to be rectangular -- use any shape you can draw as a Polyline.  You can STRETCH or grip-edit the outer perimeter as far as you need to cover things you want hidden.
Kent Cooper, AIA
tramber
Alternative solutions... how do you call them in English ? "turnarounds" ?
