I have been researching how to use a wipeout on a polyline with an arc in it, and the best suggestion I've found so far is to use the clipit command which appears to have been designed for just such a task. However upon using the command, selecting the polyline, then the wipeout, and entering an allowable error distance(which I left at its default of 1/8". The command falls apart and says:
Point or option keyword required.
(Lisp Expression) (Lisp Expression)
I have tried looking into this, and there was a suggestion to use an older lisp file from an older version of autocad, however, I do not have access to one. And on top of that, this appears to be a problem that should have an easy correction. Sadly, I have been unable to find a way to make the clipit command work. Any help or suggestions would be great.
Solved by pendean. Go to Solution.
I would try to accomplish whatever you are doing without the use of wipeouts. IME, they are not reliable.
