Circles from excel to autocad
Message 1 of 53
I have many x,y and radius values on excel file however I can't export them to autocad.
Is there any shortcut to do all in once?
Thank you
Replies (52)
Message 2 of 53
ParishSouthBdx
  1. In Microsoft Excel, open the workbook or spreadsheet that you want to access from the AutoCAD-based product.
    2. Select a range of cells to function as a database table.
    3. Enter a name for the range of cells in the Name Box, then press Enter.
    Repeat steps 2 and 3, if desired, to specify additional database tables.
    Click File  Save.
or insert table in autocad, when the form pops up, pick under inssert options FROM A DATA LINK, browse to your spreadsheet.
Message 3 of 53
but I need to create circles with these numbers in autocad. It's not only exporting excel sheet into Autocad.
Message 4 of 53
beyoungjr
Okay, it's a bit of a challenge but here's my old fashioned way...
Copy the data to a text editor or MS Word as plain text. Every line of data should end up as the x,y value and radius value.
If every line effectively has an "enter" (return) at the end then you are in business. If the radius is on the line after it's x,y value then even better.
Here's an example of how I have used line and/or circle commands to automate object creation...
L (return)
2,2 (return)
4,4 (return)
(return)
C (return)
2,2 (return)
.25 (return)
(return)
C (return)
6,6 (return)
.25 (return)
(return)
You should have a 2" line on a 45 degree angle with 2 1/2" diameter circles on either end.
If you understand the command shortcuts the you can use MS word to insert a "C" on each line before the x,y value and place an empty return between the end of one circle creation and beginning of the next.
Hope it's not too confusing? A very long text sequence will step through many processes at once, especially simple tasks like circle creations.
Blaine Young
Senior Engineering Technician, US Army
Message 5 of 53
dbroad
1) In your spreadsheet, insert a column to the left of A.
2) Assuming you don't delete your header row (1), put this formula in cell A2
=CONCATENATE("circle ",B2,",",C2," ",D2)
3)Copy that formula down to the end of the circle data.
4)Select the range A2:A26 and choose copy.
5)Paste into the AutoCAD command line.
Architect, Registered NC, VA, SC, & GA.
Message 6 of 53
Thank you very much for the reply but are you sure that the formula is correct? It seems like not working -- *Anil Baysal* *Graduate Research AssistantMining Engineering and Management DepartmentSouth Dakota School of Mines and Technology, USA*
Message 7 of 53
Now, it worked. Thank you very much!
Message 8 of 53
Dr dbroad, does it work in the same way if I want to create spheres in 3D? Because, it seems like autocad doesn't ask for Z coordinates to draw a sphere. I obtained x,y,z coordinates and r for 3D sphere locations but it doesn't work.
Message 9 of 53
dbroad
Not a Dr.  Just an architectural professor.
The fifth argument  to the concatenate function (the comma) should not have a space.  Coordinates must not be separated by spaces.
Message 10 of 53
If you mean like this, it did not work either            =CONCATENATE("sphere ",B2,",",C2,", ",D2,"",E2)
Message 11 of 53
dbroad
=CONCATENATE("sphere ",B2,",",C2,",<no space here>",D2,"<one space here>",E2)
Message 12 of 53
Sir, are you sure that this code is successful for AutoCad2015?  because I keep getting error when I use this =CONCATENATE("sphere ",B2,",",C2,",",D2,"",E2)
Message 13 of 53
dbroad
=CONCATENATE("sphere ",B2,",",C2,",",D2," ",E2)
You didn't follow instructions.  Remember<no space here> <one space here>?  You took out both spaces.
Message 14 of 53
This tip is great.  Never knew you could cut and paste multiple line into the commad line.
Used this to autocreate dwgs of some parametric designed spreadsheet parts.
However, how can I get it to work with the TEXT command which requires two Return characters after the text entry in order to return to the command prompt?
If I paste the following into the command line:
text 0,0 24 0 N22
text 10,10 24 0 N11
I get the following onscreen result:
The second command is taken as a second line of text rather then a command.
regards,
FB
Message 15 of 53
Kent1Cooper
@fredla wrote:
... how can I get it to work with the TEXT command which requires two Return characters after the text entry in order to return to the command prompt?
text 0,0 24 0 N22
text 10,10 24 0 N11
Can you structure the Excel file so that it provides the extra Return between lines?
text 0,0 24 0 N22
text 10,10 24 0 N11
Kent Cooper, AIA
Message 16 of 53
dbroad
I agree with Kent.
Message 17 of 53
Yeah, ive been messing with this for a few hours now and I came up with that solution of inserting a blank line between each line in my spreadsheet.
Works but is kind of annoying because my spreadsheet is a list of many lines (labelled circles of various sizes and positions) that get sorted and filtered by the users.
Those blank lines disappear with every sort and must be reinserted if im to paste to Acad.
Will have to write a little VBA to insert those lines as there are a few hundreds of them...
Tried adding the line feed (char(10)) or carridge return (char(13)) to the excel formula but a weird thing happens when I copy and paste into the command line:  for some reason, a double quote (") appears at the begining of each command.
So the formula is:
="dtext -" & A2 & "," & B2 & " 2.3 0 " & A1 & CHAR(10)
The text that appears in the cell is:
dtext -160,3' 2.3 0 M-1A
 (with a line feed character which shows up as a multi line cell in excel)
and this is the result of the paste into Acad:
Notice that quote before dtext...
Anyideas on how to prevent that?
thanks,
Fred
Message 19 of 53
dbroad
Fred,
You didn't follow the discussion above.  If you are combining different excel cell values into a single cell, you must use the concatenate function.
=concatenate("dtext ", ......)
The results cannot have double quotes in them.  AutoCAD doesn't understand double quotes.
Why are you sorting in Excel? There shouldn't be a need for sorting.  However, if you must, you can add a column to your sort to prevent losing the spaces.
Message 20 of 53
Helps.
Still need to insert the blank lines in notepad as for some reason they dont seen to get picked up by the copy in excel and hence dont paste into Acad..
But easier to insert those lines there rather than in excel.
Then Search and replace to remove a few hundred quote in notepad.
Still open to other solutions.
