Anuncios
Circle
Circle
No aplicable
In a circle i would like 2 line as diameter being perpendicular, but no quadrant. Can i draw 2 line without unnecessary construction? No rotate or move erase, etc. PLease reply.
COsmin.
Responder
Soluciones aceptadas (1)
782 Vistas
8 Respuestas
Respuestas (8)
Slawomir_
Use DIMCENTER command.
0 Me gusta
No aplicable
Yes, i tried. Can I rotate the lines at a angle degrees?
Thank you for reply!
0 Me gusta
kasperwuyts
Solución aceptada
Why not use rotate? It's by far the easiest way.
After you create a circle with the first line (I assume this isn't a problem), just do this to create the second line:
Click the center grip on the existing line.
Tap the space bar two times.
Press C
Press Enter
Press 90
Press Enter
Voila.
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
Kent1Cooper
It's not quite clear to me what you're trying to do -- an image or sample drawing would be helpful.  Do you mean some particular non-quadrant directions?
Draw a Line from any NEArest point on the Circle, PERpendicular to the opposite side, and Array it in Polar fashion to get the perpendicular one, maybe?
It could be automated into a routine if you can be more particular about what is needed.
Kent Cooper, AIA
0 Me gusta
JDMather
The easiest way to communicate geometry is with,.... wait for it..... with geometry.
Attach your *.dwg file here as suggested.
Are you familiar with using the Parametric tools?
0 Me gusta
dmfrazier
Have you resolved this yet?
If not, here is a way which involves grip MOVE, but no construction and erase:
1. Draw a LINE from circle CENter to your non-quadrant point on circle (use NEARest, or whatever).
2. EXTEND that line to opposite "side" of circle. (Yes, I know circles don't have "sides".)
3. Draw a LINE from some other point on the circle (NEARest, or QUADrant, any point not coinciding with end points of first line) PERPendicular to your 1st line.
4. MOVE (using MIDpoint grip) the line to the MIDpoint of 1st line (or CENter of circle).
5. EXTEND that line to opposite "side" (or "sides") of circle.
If you wanted it in less than five steps, so sorry.
0 Me gusta
GrantsPirate
I do that with a dynamic block, inserts, scales, rotates all in one command. See attached.  I have this where I insert it from my Ribbon.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
0 Me gusta
No aplicable
hi, best example in electrical diagram for tan,tan,tan, and tan,tan,radius options in circle command,
0 Me gusta
