Anuncios
CHSPACE command altering the Z-values of objects to -#.##e99
hencoop
hencoop
The CHSPACE command is jacking up Z-values of objects.  If they are MULTILEADERs, the Z-values CANNOT be fully reset to 0.0 using the CHANGE command, Autolisp, or Visual Lisp.  There is at least one unreachable Z-value that is untouched.  It can be seen using the LIST command on the MULTILEADER (the ASSOC 10, 12, 110 values have Z=0.0).
MULTILEADER Layer: "C-VI046NOTE" Space: Model space Handle = 6e0d Leader Type: StraightLeader Content Type: MTextContent
Landing: ON Leader Number: 0
Vertex: X = 1643382.1137, Y = 581080.0480, Z = 0.0000
Vertex: X = 1643392.4306, Y = 581103.7736, Z = -6.3281E+99
Multileader style: STandard Annotative: NO
I exploded one of these problem MULTILEADERs which had spline leaders (to recreate it from the text) and the splines disappeared; however, after saving the drawing, closing it, the drawing immediately crashed upon reopening.  I ran RECOVER on it and that found the splines which had to be deleted to fix the drawing.
Any ideas why CHSPACE is screwing the Z-values?
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
0 Me gusta
Responder
Soluciones aceptadas (1)
2.029 Vistas
21 Respuestas
Respuestas (21)
hencoop
@Patchy wrote:
It doesn't matter what viewport scale, it will inherit the BACKZ value when chspace is used.
This bit of information was key to finding the solution!
0 Me gusta
akitchensZEZPR
It has to do with the TARGET value not being 0,0,0.
Problem is, you can't change that value because Autodesk has made it read-only.
Instead you have to use the DVIEW command's Point option to put things back to normal. Here is the command sequence:
Dview [Enter] [Enter] Point [Enter] 0,0,0 [Enter] 0,0,1 [Enter] [Enter]
I saw that someone posted this solution but gave the instructions in AutoLISP format, so I thought I would include the command line instructions in case anybody needed to know how to fix this without writing a script.
0 Me gusta
