Choose snap setting during command for entire command?
Message 1 of 23
I would like to know if it is possible during a command to select the snap point that I want to use for the duration of the command.
For example, if I'm drawing a polyline and want to snap only to midpoints I shift+right click and select midpoint, but that only lasts for that click. I would like to be able to shift+right click, select midpoint (or other desired snap setting) and then be able to draw my line using multiple clicks, snapping only to midpoints while that command is active.
Any thoughts?
Replies (22)
Message 2 of 23
That sounds like a good idea. Curious to hear from others if this is already in AutoCAD.
Message 3 of 23
Kent1Cooper
I haven't thought of a way to do exactly that, but you could come sort of close....  You could build commands for specific entity types with embedded selection of Osnap mode(s) to be used for only that one running of the command, but to remain in effect through to the end of it.  Here's a Polyline command that asks you first what mode(s) you want, uses only that/those during the command, and then when you're finished, restores the prior mode(s) setting:
(defun C:PLOS ; = Polyline with Osnap Setting
  (/ osm)
  (setq osm (getvar 'osmode))
  (initdia)
  (command "_.osnap")
  (command "_.pline")
  (while (> (getvar 'cmdactive) 0) (command pause))
  (setvar 'osmode osm)
  (princ)
It has what might be considered an advantage over what you describe, in that you can include more than one mode.
Kent Cooper, AIA
Message 4 of 23
GrantsPirate
Easiest way is to pick on the osnap icon and uncheck any of the snap and pick only midpoint.
From the command line you can use
'osmode 2
Which could be easily made into a macro and added to a Shortcut Menu in the CUI.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 5 of 23
Kent1Cooper, I do like the option to include potentially more than one selection for the snap during a command. You'll have to help walk me through how to use your code though. I've never used anything like this before. Curious to see how easily it is executed in my workflow.
Message 6 of 23
john.vellek
Jo @Anonymous,
Have you considered setting only Midpoint in your Object Snap settings?
John Vellek
Message 7 of 23
RobDraw
Get familiar with OSMode, which can be used to set single and multiple running OSnaps, and set up a few buttons.
Rob
Message 8 of 23
Kent1Cooper
@Anonymous wrote:
.... You'll have to help walk me through how to use your code though. I've never used anything like this before. Curious to see how easily it is executed in my workflow.
Copy that code into a plain-text editor such as Notepad.  Save it to a file with a .LSP filetype ending, in some known location -- you can call it whatever you want otherwise, like PlineOsnap.LSP or something -- preferably something that will be meaningful to you next year.  In AutoCAD, type AP [the alias for APPLOAD], navigate to where you saved that file, and Load it.  Then type PLOS [the command name is always the part following the C: near the beginning of such command definitions].
It could be made a lot more sophisticated, but try out the basic version.  There's a way to have it automatically loaded in every drawing you open or start, if you need it often enough for that, so you don't need to Load it yourself.  And a command call for it can be put into menu items of various kinds, if you would use it enough to justify that.
Kent Cooper, AIA
Message 9 of 23
GrantsPirate
See the link for adding a macro to your setup.
http://autode.sk/2tkq78T
GrantsPirate
EXPERT ELITE MEMBER
Message 10 of 23
You can fire the osnap dialog box in the middle of a command by selecting the little down-arrow next to the osnap button in the tool tray then selecting "Object Snap Settings".  Any changes made there will continue for the rest of the command and beyond.
Message 11 of 23
Kent1Cooper, thanks for the additional instruction. I was able to successfully create, load, and run your lisp. The only thing is that I have several osnaps selected as my default draft settings and to uncheck the majority of them to do what I'm looking for takes too much time unfortunately.
GrantsPirates, I will have to look into setting up a macro as you suggest. I would want to set it to a single keyboard command to make it efficient.
Rculp, I don't want to alter my osnap settings indefinitely, as I like the way they are normally. I've just found recent situations where it would be nice to select one particular snap in the middle of a drawing command.
Thanks for all the input from everyone.
Message 12 of 23
Kent1Cooper
Then have it start with a clean slate, and you can pick just one or a few, without needing to uncheck anything:
  (/ osm)
  (setvar 'osmode 0)
  (initdia)
  (command "_.osnap")
  (command "_.pline")
  (princ)
Kent Cooper, AIA
Message 13 of 23
@Kent1Cooper this is much better. Thanks!
Message 14 of 23
The number in OSMODE is the sum of these from HELP:
The setting is stored as a bitcode using the sum of the following values:
0        =     NONe
1        =     ENDpoint
2        =     MIDpoint
4        =     CENter
8        =     NODe
16       =     QUAdrant
32       =     INTersection
64       =     INSertion
128      =     PERpendicular
256      =     TANgent
512      =     NEArest
1024     =     Clears all object snaps
2048     =     APParent Intersection
4096     =     EXTension
8192     =     PARallel
Setting OSMODE = 7 makes OSNAP =  End,Mid,Cen
Setting OSMODE = 103 makes OSNAP =  End,Mid,Cen,Int,Ins
Setting OSMODE = 6399 makes OSNAP = End,Mid,Cen,Node,Quad,Int,Ins,Perp,App Int,Ext
If you know the number of our favorite OSMODE setting (like 6399), or maybe a cheat sheet of your favorites, they can be set using a transparent call to OSMODE by prefixing the command with an apostrophe as in ‘OSMODE.
Adding 16384 to the current OSMODE setting turns off running OSNAPS without resetting the selection of osnaps in the dialog box.  When I use a running OSNAP, which isn’t very often it is either a specific single OSNAP (like END) or OSMODE = 6399.  So, I have a little function that resets running osnaps to my favorite:
(defun c:oss () (setvar "osmode" 6399)(princ))
Message 15 of 23
RobDraw
Let me just reiterate that those OSMode values, that @Anonymous is suggesting, can be accessed easily by adding them to your CUI with a macro.
Rob
Message 16 of 23
_________________________________________________________________________
@GrantsPirate this video is very helpful, thank you. I like having the option to access the command via a right-click or shift + right-click.
Two questions: When I added my custom command to the Snap Overrides menu, I cannot get it to show up on the right click menu as it does in your video. I have to either right click and then hover over the snap overrides to bring up an additional menu that I normally get when I shft+right click, and then I can see my custom setting. If I just shift+right click though, it does not show up in that menu. Thoughts on how to get that to work in either menu so it can be accessed via one click?
Second question: After using your method with my custom command my snap settings do not reset to the ones I had previously. I just have the midpoint snap available and then need to manually reset my OSMODE. Any way to make that reset automatically after overriding the snap setting?
Thanks.
Message 17 of 23
GrantsPirate
Make sure you drag and drop the new command to the place I show, don't let it get dragged into the osnap overrides in the menu, place it above or below that.   It won't show with Shift right click because that brings up a different shortcut menu.
I think many of us interpreted your request to have midpoint set to stay on, instead you want a one time toggle to midpoint only.  Is that accurate?  Shift+V is already set for a temp override for midpoint. While in a command, press and hold Shift+V and pick on the line, pline, etc., release and continue.
GrantsPirate
EXPERT ELITE MEMBER
Message 18 of 23
________________________________________________________________________________________________
I would like midpoint to stay on for the duration of the command and then reset back to my chosen Osnap settings. I tried Shift+V while drawing a polyline, but only get a bunch of Vs in my command line.
Message 19 of 23
RobDraw
Set-up another command with your settings.
Rob
Message 20 of 23
Depending on your MBUTTONPAN setting, a mid-button (or shift+mid-button) will pop the osnap onscreen menu (pop0), touching the letter at the keyboard that is underlined in that menu will set a one-time osnap override.
