I am revising a set of drawings, and I need to change the font and size of many text objects, making them all the same. I tried to set a new "Style", then I selected all the text objects and by right click - properties, assign this new style, but it only applies the new font size, not the font style (I want to move all the texts from Arial to Times New Roman). How can I solve this issue?
Thank You very much in advance.
Solved by j.palmeL29YX. Go to Solution.
My first guess: You don't have text objects, but MText objects?
My second guess: You (or someone) did a Font overwrite inside of the MText Editor?
If you can confirm both with yes, then I suggest to explode the Mtext objects to text objects. Now it should work.
Jürgen Palme
Perfect, actually I don't know which kind of object it was...I'm not so expert in Autocad, but I exploded the texts and now it works! Thank You very much!
