Changing splines to polylines
jimbir
jimbir
hi. I'm working with ACAD 2004. I have a spline I would like to convert to a polyline. I've seen numerous posts saying this can be done using the PEDIT command. If I try to follow those instructions, I get a message telling me that what I selected was not a valid polyline.
Can someone tell me how to do this with my antique version of ACAD?
0 Me gusta
Responder
7.430 Vistas
7 Respuestas
Respuestas (7)
chriscowgill7373
do you have express tools?  You can flatten a spline and it will convert it.    I dont think spline conversion using the polyline command was added until recently
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
0 Me gusta
Alfred.NESWADBA
Not with AutoCAD 2004.
If my remembering is correct then yo might save your drawing back to DXF12, that converts splines to polylines.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
leeminardi
You can convert a spline to a polyline with the splinedit command.  I am not sure if the command is available in 2004.  After giving the command input the P option (polyline)and then enter the level of smoothness you want.  If the original spline lies on a plane a polyline will be created.  If the spline did not lie on a plane you will get a 3dpoly.  You can convert a 3dpoly to individual lines with explode.
lee.minardi
0 Me gusta
maratovich
Copy the spline to a new file .dwg
Save the new file as ... in version AutoCAD R12/LT2 DXF  .dxf
Close file .dxf
Open file .dxf
Copy a polyline from a file .dxf to an old file .dwg
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
0 Me gusta
jimbir
I attempted to install express tools using the install disk but it wasn't in the list of features. I can change an arc to a polyline but not an ellipse. An arc doesn't give me the area I need. (I'm laying out an aircraft instrument panel.). I'm going to see see if i can generate an arc that has an area close to half an ellipse. I'll get back with results.
Jim
0 Me gusta
jimbir
Thank you Alfred, Leeminardi, Maratovich for the work-arounds. I try them out.
0 Me gusta
jimbir
Splinedit does exist in 2004 but the P option isn't one of the options.
0 Me gusta
