Changing or matching reference planes
tsakani_mdabula
tsakani_mdabula
I want to transform or project drawing_1 to match drawing_2. I am able to overlay drawing_1 to drawing_2 using xref method, where i rotate drawing_1 by 180 degrees. See below: Drawing_1 in red, Drawing_2 in blue,red, yellow
However, what I want to do is to change the drawing_1 to match drawing_2, so that I can xref it without using the rotation option. Another method that I used was to bind the drawing after I xref it, but I had to explode as it was added as a block and needs repetition when changes are made to drawing_1.  The main point I want this is because i use QGIS to make further analysis and it doesn't have the option to rotate the drawing when I add to it, thus they have to be in the same plane before being added.
paullimapa
Why don’t you do the reverse
Open drawing_1 and reference drawing_2
Now rotate All but drawing_2 to match
Lastly detach drawing_2
Save and close
Now when you open drawing_2 and reference drawing_1 it should match perfectly
Paul Li
IT Specialist
@The Office
tsakani_mdabula
Thanks, Paul. I would do that, but I have more than 15 drawings similar to drawing_1. At the office, we use GMS for geological structures and integrate them into the mine designs in AutoCAD. We have a substantial database, so I need a way to change drawing_2 to fit without rotating it to match drawing_1. If you check drawing_2, you'll see it is rotated by 180 degrees. Aligning them in AutoCAD is not an issue, but I encounter problems when using GIS software.
paullimapa
Unfortunately since you have no control over the GIS software your only choice is to control when you receive the dwgs. Why did you set the rotation in drawing_2 that way?  If you change it to match drawing_1 then from this point forth your problem is solved. There’s also a way to select a folder where you may store all your GIS dwgs and rotate them all using the same parameters that only works if the rotation parameters are all the same of course
Paul Li
IT Specialist
@The Office
