Changing of the height of a selection of texts in a drawing globally.
ber999
ber999
How can I change the height of all texts in a selection of a drawing globally?
Moshe-A
@ber999 hi,
if the selected texts share the same height, select them with QSELECT then go to PROPERTIES and set a hew height but if they are on varing heights then automating is needed.
moshe
Kent1Cooper
Make your selection of whatever collection of things, and in the Properties palette, pull down the list of selected objects and pick on the Text one to narrow the selection down to only those:
and then further down, change the Height of all of them together:
that is, assuming you want them all to have the same  height.  If you want to do it to both  plain Text and  Mtext, you will need to do it separately for each category.
Kent Cooper, AIA
