Does anyone know how or if it's possible to change the grip of the mline to the center end point? (Per the blue arrow above showing where I want the grip to move to). Helps with snapping to objects.
(I was hoping to avoid clicking on the grip and right clicking and selecting base point).
>> Does anyone know how or if it's possible to change the grip of the mline to the center end point? <<
i suggest to change the Justification to Zero and see if that serve you.
Command: ml MLINE
Current settings: Justification = Zero, Scale = 0.50, Style = STANDARD
Specify start point or [Justification/Scale/STyle]: j
Enter justification type [Top/Zero/Bottom] <zero>:
You can also change the justification of already drawn mlines by selecting them and changing the justification to zero on the properties palette. see pic
@imadHabash wrote:
i suggest to change the Justification to Zero ....
That will change the geometry of the Mline. If you want to keep it the same, I don't know of a way to change its justification -- you may need to draw another over it, using M2P/MTP Osnap at each vertex.
