Changing layout view color
hi
how can I change layout drawing color without change model color
not layer override option
Kindly  check the attached drawing and advice us .
pendean
Community Legend
Community Legend
You can only use the method you do not wish to use: sorry.
imadHabash
>> how can I change layout drawing color without change model color not layer override option
Pick inside your VP then type layer command . check VP Color tab . this is your choice .
Imad Habash
user181
Hi @Anonymous   Go to the layout tab AO and use the start PAGESETUP command. Then click on the Modify button in the first dialog and then in the page setup dialog uncheck the "Display plot styles" option to change the colors in layout to the same as model. Or check it to show how it will look when printed.
dbroad
If you mean, change the few colored objects in the layout to black, then it is impossible without changing their color. The few objects that are in color are set to a true-color, which isn't supported in CTB plotting.  There are also many objects and nested objects set to a color other than bylayer.  So viewport overrides won't work.
If you create a layer for each truecolored object and set those layers' colors to the same truecolor used for those objects, then you could set a viewport color override.  This would be the easiest approach while keeping the model space appearance the same.
Another very complicated approach would be to change the drawing to a style based plotting system. This is impossible to accomplish however without custom programming, since it would involve changing the plotstylenames of many nested objects and attribute references.
Architect, Registered NC, VA, SC, & GA.
