CHANGING LAYER PROPERTIES, IGNORING MISSING LAYERS
I am workingona script routine to batch run on a large number of files.  I want it to rename a couple layers, Change layer colours and add a new layer.  I can get it to do all these things, except if a layer is missing.  The files that i am importing may not have layer 'c' but i am changing properties for layers 'a,b,c,d,e' Because the script cannot find layer 'c', it crashes the script. How do i tell the script to ignore a layer if it is missing?  below is a sample of the script.
z
e
(if (tblsearch "LAYER" (substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 4)))
  (command "_rename" "_layer" (substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 4)) "cut"))
-rename
La
Scribe-text
Etch
-rename
La
NO KERF _ CUT _ NO LEAD-IN
Cut2
-la
n
bom
-la
s
bom
-la
lc
rgb
0,0,255
-la
s
cut
-la
lc
rgb
0,255,255
-la
s
etch
-la
lc
rgb
255,0,255
-la
s
display
-la
lc
rgb
255,0,0
-la
s
cut2
-la
lc
rgb
0,200,200
cadffm
Without programming
Create layer first
-LAYER
THAW
C
MAKE
C
RENAME LAYER
C
newname
Sebastian
Kent1Cooper
What version are you using, and/or overlay program?  I don't have [in 2019, and Help for 2020 doesn't mention, nor do I recall from earlier versions going way back] a LC option in -LAYER, and RGB is not the way to use that kind of color [it's the Color option and then beneath that the Truecolor option].  But in any case:
You don't need to make a Layer current in order to assign a color to it.  And if you do it by naming the Layer(s), and there is/are no such Layer(s), a message will go by that it didn't find it/them, but it won't crash -- it will just go back to the main prompt.  Also, you can combine all of this into one  Layer command -- you don't need to complete the command and then start it again, but can just choose further options and carry on.  Using my kinds of command options:
-LAYER
make ; this creates it like New option, and makes it current in the process -- no Set option required
bom
color Truecolor
0,0,255
color Truecolor
0,255,255
cut
color Truecolor
255,0,255
etch
color Truecolor
255,0,0
display
color Truecolor
0,200,200
cut2
Kent Cooper, AIA
cadffm
@Kent1Cooper  schrieb:
-LAYER
Only if the Layer is not already there &freezed,
that's why i answered with the bulletproof way, first thaw, then make:
@cadffm  schrieb:
Without programming
Create layer first
-LAYER
THAW
C
MAKE
C
RENAME LAYER
C
newname
Sebastian
Kent1Cooper
@cadffm wrote:
.... first thaw, then make:
Yes, that's a good idea if it's possible that it might exist but be frozen, since a frozen Layer cannot be made current as the Make option will want to do.
[Why you would Make a Layer and then immediately rename it is beyond me -- just Make it under the desired name in the first place.  But if there's some reason to do it that way, there's a Rename option  inside the -Layer command, so you don't need to close Layer and open up a Rename command.]
Kent Cooper, AIA
Thanks for the help guys.  I had to have one of our programmers step in and write it up for me.
