AutoCAD Forum
changing dimension geometry
3 REPLIES 3
jdfnnl
276 Views, 3 Replies
Is there a way to place dimensions with an angle other than 90 degrees between the dimension & extension lines?
3 REPLIES 3
Valentin-WSP
in reply to: jdfnnl
@jdfnnl
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Kent1Cooper
in reply to: jdfnnl
That's called "obliquing."  Draw the Dimension, then use DIMEDIT and the Oblique option, and give it the angle at which you want the extension lines to aim from the definition points.  This is a vertical Dimension with an obliquing angle of 30°:
I don't think you can draw one directly that way, but you need to draw it and then edit it.
Kent Cooper, AIA
clear, concise, great answer Kent.
Forma Design Contest
