changing default print options (destination folder)
jetted4
jetted4
Hi  :cara_con_una_leve_sonrisa:
My computer was recently reformatted to fix a bug but all of my settings reverted to defaults it seems.
One that I can't figure out how to fix is the default print to file location.
When I try to publish multiple pages (to PDF), in the pop -up menu there is a box labeled Publish Options.  There isn't anything in the menu I can click on to choose that the default print location be the most recently accessed folder.  When I try to delete the default folder ...\cadprintjobs\ in the hopes that it will then ask, Autocad crashes.
How do I set this the way I need?
0 Me gusta
Responder
1.359 Vistas
8 Respuestas
Respuestas (8)
pendean
Community Legend
Community Legend
So you cannot do these five steps in PUBLISH command to do what you want?
0 Me gusta
jetted4
I am able to change the print location as you marked, but that's a default directory.  What I want is to remove that default location and have it assume it should print to the most recently printed to/accessed directory (i.e., wherever I printed to last time).
Not a huge deal, but it used to do that before my PC got reformatted and it's kind of a pain since we have a lengthy directory structure to have to specify everytime where I want it to print to if I am making changes to the same file and need to reprint to PDF.
0 Me gusta
pendean
Community Legend
Community Legend
Not an option once that default is set AFAIK, its a long term wishlist.
Do this built-in folder navigation ability as a workaround for now while others chime in with other ideas https://envisioncad.com/save-your-favorite-locations-in-autocad/
HTH
0 Me gusta
jetted4
Thanks :cara_con_una_leve_sonrisa:
The tips in the link look like it's just for saving files, though, not printing to a file.
I inherited this PC from a former draftsperson at our company.  Until just recently when my machine was reformatted to get rid of a computer restart glitch, printing to a PDF in Autocad always used to offer the last used file directory, not a default, so it must be something that Autocad CAN be set for, but I lost that setting with the PC reformat....
0 Me gusta
pendean
Community Legend
Community Legend
This tip is about how to add folders to the sidebar in AutoCAD's pop-up from OPEN, PUBLISH and way more: it is worth trying before dismissing since it works just fine :cara_con_una_leve_sonrisa:
But hey, what do I know LOL
0 Me gusta
jetted4
I am sorry.  I wasn't trying to dismiss.  When I skimmed through it I didn't see anything for Publishing so I guess I looked at it too quickly.
Thank you.
0 Me gusta
RobDraw
I'm away from CAD so I can't test this before posting.
Does changing the value of REMEMBERFOLDERS do anything for that?
Rob
0 Me gusta
jetted4
Looking at the description, it seems like it ought to, but mine's already set to 1.
Strange, though, that when I just tried printing again, when I selected only a single page, it remembered the previous print to folder, but when I try to print multiple pages to PDF (which is 99% of the time what I need) it will not remember now, just goes to the default folder specified at the top in the publish options menu every time...
0 Me gusta
