Changing Block Layer
Bob0815
Bob0815
im a beginner and have autocad2025.
My problem is that I’m trying to copy a block and change its layer so I can experiment with it without messing up the rest. However, after I copy it and change its layer successfully, the block goes back to its original layer when I open the Block Editor.
I’m honestly afraid to change anything on that layer or to those blocks, because they are used in hundreds of drawings!
So I thought I could just copy the block and change its layer, but for some reason it’s not that simple.
Can somebody give me an advice please?
Accepted solutions (3)
VincentSheehan
Use BEDIT and use Save As to a new block name. Edit the new block without changing others.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
imadHabash
To change a block's layer in AutoCAD, select the block and choose a new layer from the Properties palette or dropdown menu. For objects within the block to update, they must be set to Layer "0" and properties set to "ByLayer" using the Block Editor. Use SETBYLAYER to force all nested items to adopt the container layer's properties.
Imad Habash
jreidKVSUZ
Bob,
Many times I have done this and want a clear shot at setting the block up.
I usually do an EDIT COPY. The start a clean drawing and EDIT PASTE-ORIGINAL-LOCATION.
Go to the Layer Command and change the layers as needed. Be sure to Rename the Block to a New Block Name.
If you don't and your try and bring the block back into the same drawing, the existing block will be the layers the block will use and not the ones you did in the new drawing.
But with that said, read the following and you can update the existing block inside your existing drawing as well if you want.
To bring in a block and update existing instances in AutoCAD, use INSERT and select the "Redefine" option when prompted, or use the CLASSICINSERT command. Alternatively, dragging a block from the DesignCenter (ADC) or using BLOCKREPLACE (Express Tool) effectively updates block definitions across the drawing.
Best Methods to Update Blocks
INSERT (Redefine Option):
Type INSERT and browse for the updated source drawing (DWG) containing the block.
If the block exists, AutoCAD will ask if you want to redefine it. Choose "Redefine" to update all instances.
CLASSICINSERT (Simpler Redefinition):
Use CLASSICINSERT to open the old insert dialog, browse, and place the block.
If the name is the same, click "Redefine" to update all existing blocks immediately.
DesignCenter (ADC):
Press Ctrl+2 to open DesignCenter.
Find the file with the updated block.
Right-click the block, choose "Redefine Only" or "Insert and Redefine".
BLOCKREPLACE (Express Tool):
Type BLOCKREPLACE.
Select the old block to be replaced and the new block file.
Key Commands for Block Maintenance
BATTMAN (Block Attribute Manager): Use this if the attributes (text) within the block did not update.
ATTSYNC: Forces all instances to sync with the updated block definition.
REFEDIT: Edits the block directly in the current drawing.
Hope this helps!
Thanks, JRR!
chriscowgill7373
Welcome to the forums.
Being new to the software,  terminology can be different.   Can you please explain a little more about your workflow?  Are you attempting to modify the layers of entities within the block, or the layer the block resides on within the file?  When you make a copy, how are you making the copy?  Blocks, within a drawing are defined by their name.  Every instance of a block within a file that has that name is identical.  There are dynamic blocks that can be modified to look different,  but they are still at their base, identical to other dynamic blocks with the same name.
Aa was alluded to above, blocks that contain entities on layer 0 can take on the appearance of the layer they are placed upon in a drawing.
Are you able to share some screenshots of what you are working with?  That may help to clarify the process you are describing.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
navya_gelli
Hello @ykermann ,
It looks like you have received a lot of advice on this thread. Did any of the replies by @VincentSheehan @imadHabash @jreidKVSUZ @chriscowgill7373 answer your question?
If you are still needing more help, please share an update here. The community will be happy to jump in and suggest more steps to help you get where you need to be.
Best,
Navya | Community Manager
