Changes on Drawing Properties are not appearing on DWG file
syanchuck
Message 1 of 9
syanchuck
I made some changes on the Drawing Properties, however nothing changed on the file, even after regen. Once I've created PDF file, all changes are appearing.
What's that?
Replies (8)
Message 2 of 9
ara_neresesian
HI
some changes like linetype scale,color or line width are difficult to see the difference, in page layout and model space
(depends to page setup and printer ,color printing or gray scale)
but the rest change must be every where.
Please explain which properties you changed,and if its possible make a screen shot from  difference.
good luck
Message 3 of 9
syanchuck
That is the frame. I had previously 9 sheets on the drawing, but I've merged sheet 2 and sheet 3 together. I've moved former sheets 4, 5, 6, 7, 8 and 9 on the model space and they became accordingly sheet 3, 4, 5, 6, 7 and 8.
On the paper space frame total sheet number is appears as 9 and all sheets appear as 8 of 9 except sheet 1 that is still appears as sheet 1 of 9.
However in PDF everything is good.
Message 4 of 9
syanchuck
I meant, that the change is on the Drawing Utility - Drawing Properties (see image Proprties1).
On the Image Properties2  is what on the DWG file, In the image Properties3 is what on the PDF file.
Message 5 of 9
ara_neresesian
save and close and reopen it
if there is  a issue, uplaod the cad file (you can delete everything just do not delete the titles )
Message 6 of 9
user181
Hi @syanchuck   Go to OPTIONS and on the User Preferences tab click the Field Update Settings button and check all the boxes for automatically updating fields.
Message 7 of 9
syanchuck
I need to think how to delete all sensitive information since every single sheet is actually different block with attributes and I need to change all of them. Will try to send it later.
Message 8 of 9
syanchuck
Saved, closed, reopened. everything is still the same.
Message 9 of 9
syanchuck
Super! Worked well!
