Hi @Moshe-A , you did it, that's exactly what I wanted. Thanks you for doing this.
I use this paletette for plotting old underground plan (TIFF/JPEG) with AutoCAD Raster Design. For readability I don't use the acctual pipe diameter, it's too small and too big for scales 1:250, 1:500, and 1:1000.
I'm not familar with "pipes.VLX", it seems to work with this palette only. This palette I only use for 8, 12, and 15mm (the same pipe diameter), I have other palettes for bigger pipe groups.
Using your idea, block attributes I was able to create dynamic block that I wanted, even though it is more like half dynamic, but I can live with that.
It seems logical to me to have an option for changing block perperty from other block, that's why I thought this option must be exist somewhere in AutoCAD that I didn't know, but it doesn't seem to be the case. This workaround is good enoght for me, thanks again for your help.
