Change the default dimensioning style when creating a new drawing
1911504210134
1911504210134
Community Visitor
Community Visitor
Hi there, I'm a basic autocad user, I want when I create a new file or open someone else's drawing, my dim is 5 times larger than the default size without having to scratch the dimstyle.
thisispreston
DIMSTYLE command will let you set up your own dimension style with larger text and whatever other properties you want.... colours, font, arrowhead size etc.
Just hit "New" in the DIMSTLYE pop-up window, you can pick an existing one as a starting point and then change the relevant bits for what you want.
"music is my religion" - Jimi Hendrix
ennujozlagam
dimstyle: modify/ new
Valentin_CAD
@1911504210134 ,
@1911504210134 wrote:
... my dim is 5 times larger than the default size ...
Hopefully I understood you correctly.
If your dimensions are 5 time larger than the default size, then you may be using an Annotative dimension style.
In the Properties, change the Dim style or Annotative status.
You may also want to check the Measurement scale:
Note regarding measurement scale:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
