- Mute
- Permalink
- Report
Is there a way to create an attribute in a block, but to make the attribute in such a manner, so when you change the symbols in the attribute for a particular block, it doesn't change throughout all the copies of the block in the drawing, but when you change the position of the attribute in this particular block, the position of this attribute applies to all of the copies of the block in the drawing.
Let me put this in example and pictures:
(1) In the attached file (IAsk.dwg), you can see three circles with text on them — every circle is the same block repeated three times in the drawing and the text is an attribute to the block.
(2) I double click the Val.1 to change the value of the attribute in the first block, from Val.1 to Val.1.1 for example.
(3) The result is exactly what I am looking for — the change of the attribute applies only to the current block.
(4) If I want to move the attribute, there is also no problem — the attribute moves for the current block without any displacement of this attribute in other copies of the block in the drawing.
(5) The actual problem occurs, when I want to move the attribute inside the block editor and it doesn't move throughout any of the instances of the block in the drawing — I want it, because in an actual drawing, I need to move the attribute of a certain block, that is already replicated several tens of times and I don't want to move every attribute for its own, but I rather believe, there is a way to do this automatically.
(5.1) Within the block editor I move the position of the attribute.
(5.2) What I want: to have the position of the attribute in the drawing applied over every copy of the block in the drawing
(5.3) What I get: the new position is not applied anywhere in the drawings and according to my so far knowledge, I have to move the attribute manually at every instance of this block — this certainly I will try to avoid.
I had a couple of tries with the block editor's Parameters and Actions, but no success so far.
If you know a way to achieve the outcome from (5.2), I kindly ask you to share it here.
I hope my question is properly explained and a helpful colleague with a solution will soon spot my question.
Thanks in advance.
Edit: Due to a reason I am unaware of, the attached file is missing form my original post, but now I am adding it in this edit.
