Change text styles across multiple dwg files
jamaine.murphy
jamaine.murphy
Hello Community,
Is there a tool/lisp/routine availble to perform a mass textstyle properties change across multiple dwgs?
I'm looking to change the font type for a specific textstyle across all my dwgs.  Is there a way to do this without going into every dwg file and changing it manually?
pendean
Community Legend
Community Legend
You need to know the STYLE name inside each DWG file.
You need to know the new font name to substitute.
Then you can write a script file, and use a batch script processor to run it across as many DWG files are you need.
How far did you get so far in your testing in one DWG file?
jamaine.murphy
Ah okay. So its possible, kewl.
However, I've no idea how to do what you've suggested.
Could you point me in the right direction to do this.
pendean
Community Legend
Community Legend
HELP is a good place to start learning about SCRIPT file creation https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-BE44AE86-7638-48C9-BE5B-C1DF8E4C8808
This online tutorial is less technical https://xlncad.com/scripting-in-autocad/
Here is n online tutorial about using a script batch processor with your successfully tested SCRIPT file https://www.cad-notes.com/run-a-script-on-multiple-dwg-with-scriptpro/
TerryDotson
If you were to consider third party add-ons, DotSoft's ToolPac contains a Style Merge tool that works across multiple drawings.  The files are not actually opened in the editor meaning extremely fast processing versus scripting.
