Hello.
I have Mtext that content is 1~50 (not '1~50' but '1','2','3'....) in my drawing.
However, I have to change text of content as having pattern such as '1' -> '750', '2' -> 751.
So, I changed individually text, but It takes a long time to finish my work.
Because I have a lot of text to change it.
Is there way to solve the problem?.
I found the srxtext lisp file from cadstudio to solve the problem.
I thought that the lisp helps me out.
However, To handle srxtext lisp, I must have to know that regular expression but I don't know that how to access it.
Solved by 3wood. Go to Solution.
Hello
I have a question about point manager.
When I convert point to CSV file, If I create points sequentially, the point of XYZ coordinate in CSV file will be located by created number.
Is it right??.
