Change text height in layer manager
orenreedy
orenreedy
Community Visitor
Community Visitor
How do I change the text height in layer manager?
ChicagoLooper
Sorry, you can't change text height in Layer Manager. You can, however, change it using the Properties Palette. First, select your text(s), then in properties palette go to Text section and change the text height.
Chicagolooper
Moshe-A
@orenreedy  hi,
if you mean enlarge the text size of Layer Properties manager palette (dialog) then this can be change in windows display settings (control Panel\Display), setting a higher size will also increase the icons on your desktop.
Moshe
imadHabash
what a tricky question ... for the first moment it tooks you for a the Text entity BUT in real i agree with @Moshe-A  answer . 😉
Imad Habash
