CHANGE ROTATION IN VIEWPORT
Message 1 of 11
Good afternoon all.
I have a problem wherein I need to rotate the view of a drawing object within a viewport, without actually rotating the object in model space.
A former coworker had showed me once where I could reverse the view--- looking at the object from the A side to looking from the B side. Now, I want to rotate the orientation inside the viewport.
I hope this is clear enough. If not, please let me know.
TYIA.
Accepted solutions (3)
Replies (10)
Message 2 of 11
paullimapa
You can use the good old DVIEW command with the TWist parameter:
DVIEW
<enter>
Twist
enter your rotation angle
Another method would be to use the UCS command with UCSFOLLOW enabled:
UCSFOLLOW
1
UCS
Z
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 3 of 11
pendean
Community Legend
Community Legend
Rotate the viewport: that's right, select the viewport outline, start ROTATE command, select your angle, and be done.
But you seem to want MIRROR instead... .
Message 4 of 11
Emmsleys
Hi @Anonymous
There are two options you could try that can help with rotating a view within a viewport.
  1. Rotate view by changing the UCS
  2. Rotate a view within a viewport
Please select"Accept as Solution" if my post resolves your issue, or reply with additional information if the problem persists.
Thanks.
Sarah Emmsley
Technical Support Specialist
Message 5 of 11
3wood
Please ensure VPROTATEASSOC is set to 1 if ROTATE doesn't work as expected on you viewport.
Message 6 of 11
Alfred.NESWADBA
my prefered tool to adjustion the view-rotation is the viewcube:
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 7 of 11
jackshield
GOOD TIP!
how do you rotate in 3d axis?
Message 8 of 11
Alfred.NESWADBA
click onto corners or edges of the cube, this brings you to predefined views.
And completely free orbit can be done by
  • click and hold a corner of the viewcube while moving the mouse
  • click and hold <SHIFT><MiddleMouseButton> and move the mouse
- alfred -
Alfred NESWADBA
Message 9 of 11
jackshield
I have always used dview and rotated by certain angles when modeling equipment, but this could help for standard views.
Sent from my iPhone
Message 10 of 11
thank you, one and all for your responses.
Please pardon my delayed response. I got sick, and was out for a day.
I did find that the VPROTATEASSOC did what I'd wanted.
It was not however what I was initially thinking.
As stated in my initial post, this colleague who'd shown this to me had used something like -view, or -vport. I did just try this and it did not work the way I was expecting.
I don't remember specifically. But what it did was to show the reverse side of the object.
And no, it was not mirror.
I do like the wheel. I'd used it before, but that was sufficiently long ago that I'd forgotten-- thank you for the reminder.
I think that one of these two items will probably be what I'll use for the time being.
Again, thank you.
Message 11 of 11
alcohen
What would cause the small arrows on the view cube to not rotate the view?  Someone gave me a drawing to edit for them, and they are not working.  If I create a new drawing, or open any of my old drawings, the arrows work fine.
I tried the vprotateassoc command on both a 1 and 0 variable but that did nothing.
Thanks!
