Change Properties of Block inside Blocks
jyothissurendran
jyothissurendran
I have a block with so many blocks inside with different properties. Is there any option to change the color in single command ?
Jyothis Surendran
Autodesk Autocad 2014 & Inventor Professional Suite 2010
Windows 10
0 Me gusta
Responder
703 Vistas
5 Respuestas
Respuestas (5)
imadHabash
 depending on your elements properties you can try SETBYLAYER command ( check the Settings ) .
Imad Habash
0 Me gusta
jyothissurendran
No... it will not work for my purpose. BCZ all layers are in different colors assigned. I wanted to change all objects (line, circle, etc inside the blocks) to a single color.
Jyothis Surendran
Windows 10
0 Me gusta
Alfred.NESWADBA
is this just a one drawing issue? Then please upload the file, let me know the color you want to assign to all your block definitions and I'll convert it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
jyothissurendran
No.. its not for one file. Always facing the issue different files. Due to some reasons i cant't upload the file.
Jyothis Surendran
Windows 10
0 Me gusta
Alfred.NESWADBA
in this case you'll need to search for a tool or write your own one.
A good start could be >>>here<<< (first with LISP is the most viewed forum, but it depends on your skills, where to search or place your question).
- alfred -
Alfred NESWADBA
0 Me gusta
