Change multiple attributes inside a block like a string
marius_seldalS44A9
marius_seldalS44A9
I would like to make some kind of string were i can have 8 attributes: I0.0, I0.1.....I0.7, but only the first digit need to change., from I0.0 to I1.0. Is it possible to make all 8 change at one time? Now i need to change all of them as a regular attribute but that take time when i have 20 sheets with different adresses.
It is the red text over the inputs on the PLC card i am thinking of.
See attached dwg.
cadffm
and why not just FIND 0. or I0 and REPLACE with 1. or I0
Sebastian
paullimapa
Adding to @cadffm replied, when you use the FIND command make sure you click on the drop down arrow on the lower left hand corner to see more options:
The dialog window will expand showing more options.
Make sure Block attribute value toggle button is checked.
Now you can enter the Find what & Replace with values in the edit boxes.
You may want to toggle the List results box on and then click the Find button:
The list window would update & an alert window would appear showing # items found:
Last click the Replace All button to complete the command.
Paul Li
IT Specialist
@The Office
