Change multiple attribute values for different blocks within Properties window
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The software:
Person #1 has AutoCAD 2021 V 47.0.0
Person #2 has AutoCAD 2021 V 47.0.0
The problem:
Person #1 can do something, Person #2 cannot even though they have the same program.
Person #1 can edit the value of an attribute for multiple different blocks (2+) at the same time in the properties window.
Person #2 can edit the value of an attribute for multiple of the SAME blocks (1) at a time in the properties window.
See (3) images attached. Note that Person #2 has a "Block:" callout next to the attribute, I suspect that the solution lies in removing that "Block:" callout..
The question:
Clearly, this is a option or command that can be changed since we have the same program. We want to know, what is that command? How can Person #2 get the same functionality as Person #1?
Said another way: How can Person #2 edit the value of the "array" attribute for multiple and different blocks that have the SAME attribute?
Note, I'm NOT looking for a lisp command, or the GATTE command, or BATTMAN. None of these work for what I'm specifically looking for. Person #1 can clearly do it without any lisp commands or anything special. So something must give person #2 that same functionality. Also note that Person #2 can edit attributes for multiple blocks of the same name, but not multiple blocks with different names.
