Change MText height using IF statement in C#
I'm trying to change the MText height and position using an if statement, so that when the user chooses a number (e.g 100) the text changes its height to 5. The problem is that value doesn't change it always stays on the default value and position inside the else statement. I tried the switch cases but still the same problem...
if (scaleValue == "100")
                        MText mText = new MText();
                        mText.Location = new Point3d(pointFourX+5, pointThreeY - 10, 0);
                        mText.Contents = $"{circles}T14,2φ8(12→26) ";
                        mText.TextHeight = 5;
                        mText.LineSpaceDistance = 33;
                        acBlkTblRec.AppendEntity(mText);
                        acTrans.AddNewlyCreatedDBObject(mText, true);
                    else
                        mText.Location = new Point3d(5, pointSevenY - 50, 0);
                        mText.TextHeight = 20;
ВeekeeCZ
@Anonymous
Better post your question to some customization forum HERE . There are folks that understand the C.
