Announcements
Change drawing format
364877
364877
After using Autocad, I save as dxf and when closing the files constantly "Save with dwg format?" Is there a way to close or prevent this question?
Replies (21)
imadHabash
I think that you need from Options >> Open and Save tab >> File Save .. you need here to change your save as format , any changes now ?
Imad Habash
Hi, I did what you said before but Autocad still keeps asking. I uploaded a photo so you can see.
imadHabash
Try the solution mentioned here . >> Click <<
Hope it's help you ..
Imad Habash
RobDraw
AutoCAD has registered a change(s) and is verifying that you want to close without saving said change(s).
Rob
it asks this question even when i save the file or don't make any changes
RobDraw
Apparently, you have a different definition of change than AutoCAD does.
Rob
I looked the page but I dont know ''LISP''. What is that mean?
I thınk I can explain you like that '' If I open a file to look inside and close it without making any changes, it asks the same question (save in Autocad 2018 format?). This is not a problem for a file but sometimes I  use too many files in same time and it can be very difficult to answer all of them one by one. I have had enough of it!
pendean
Community Legend
Community Legend
@364877 If you only wish to open and look inside files all day look, but make no edits at all, use a viewer app instead of an editing app for the task.
Correct tool for the correct task is the better approach.
Kent1Cooper
When you use SAVEAS to make a .dxf version, it takes you into that .dxf file [just as it takes you into the new .dwg file if that's what you choose], so you are no longer in the .dwg file you started in, which is quite a change.
Use SAVE [not any so-called "Save" icon or menu item, all of which really get you the QSAVE command -- type in SAVE] rather than SAVEAS.  It leaves you in the current .dwg file, and [in quickie trial] that question is not asked on Closing.
Kent Cooper, AIA
Hi, Your advice so good but I use Autocad for laser cutting so I open too many files, copy them and I am preparing in a file. So I must open them with Autocad.
I always use dxf format in Autocad and even though I changed the save format from the options but Autocad still keeps asking the same question.
RobDraw
It seems that you could solve this with a little customization. LISP, macro, action recorder are a few.
Rob
pendean
Community Legend
Community Legend
Got it.
Post a screenshot of your OPTIONS command's OPEN/SAVE tab please. This is the same suggestion as reply #2, but your reply in #3 would indicate you did not follow through with it. OR AutoCAD cannot do what you want, in which case you will have to find a different CAD program that will do as you wish.
TIA
Kent1Cooper
@364877 wrote:
I always use dxf format ....
I had interpreted your wording "After using Autocad, I save as dxf" to mean you were saving to .dxf format from working in a .dwg file.  I wasn't aware the you can actually work in a .dxf file, but it looks like AutoCAD doesn't think that's a good idea, because any kind of saving brings up the dialog box where you need to re-specify .dxf format if that's what you want, every time, since it defaults to .dwg.  Is there some reason you don't just work in .dwg format?  A simple Ctrl+S / QSAVE would then save it without the need to go through that dialog box every time.
Kent Cooper, AIA
Washingtonn
The QSave suggested by Kent works well until you exit the drawing.  The AutoLisp shown below can be set up to auto load and assigned to a button so that when it is selected, the DXF file first saves and then closes without the drawing pop-up displaying.
(defun C:SaveCloseDXF () (command "saveas" "dxf" "v" "2018" "" "~") (command "._close" "_n") )
The tilde "~" will bring up the navigation dialog so you can choose the location to save the file or overwrite the existing file.
I uploaded a screenshot of my OPEN/SAVE command tab. As you can see in the red arrow, it has updated dxf setting but it still continues to use dwg format. I dont care what it use but Autocad askes the same questıon all time.
Bir dosyayı kaydetmek için genellikle CTRL+S kullanıyorum ama bu yöntem çalışmıyor. İstersen ekran kaydı da alabilirim. Dosya dxf formatında olmasına ve kaydetmeme rağmen sürekli soruyor ve gerçekten can sıkıcı bir hal alıyor.
I tried these methods (qsave and CTRL+S) but these arent working. I heard AutoLisp first time, I will download and try this. May be it will work.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
