- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I’m currently using AutoCad 2021. I am a novice user using AutoCad for reviewing/editing engineering drawings and for rudimentary sketches when other presentation platforms aren’t precise enough for my purposes. That being said, I am supporting the mobile food pantry program for our local foodbank by managing COVID safe delivery of two USDA food programs at several senior living complexes in our area. To do this, I use excel to pre-register residents, and indicate if they receive one or both food programs based on entries in column A (CSFP program) and column B (TEFAP program). Columns A and B are conditionally formatted to change column A entries to green when selected and column B entries to pink when selected. I have drawn maps of each apartment complex, in which I highlight each apartment on the printed map by hand with pink and/or green to match the excel file. What I would like to do is update the map using the excel file to automatically color the apartments based on the excel file data. I have seen several similar inquiries for hatching, filling objects based on excel data but none quite do what I want. I’d like to redraw the map so that the apartment and apartment numbers are on a layer, blocks containing the pink fill color is on a layer, the green fill color is on another layer, and frozen layer to turn fills off. I’d like to generate commands in excel to change the layer of the block fill to the green layer or the pink layer or to the frozen layer, then paste the commands into the drawing to make the map colors match the excel file. I’m happy to paste the commands in manually, but would like to explore the use a script file to automate if I can make this work manually. This seemed the best way to me since there are approximately 150 apartments at each complex and I haven’t found a good way to do this controlling the colors of individual blocks with attributes using excel data. Is there a better way to do what I’m trying to do? I’ve seen similar posts on other forums but none have answered the query. I have attached a sample excel file and sample maps to illustrate what I’m trying to do.
