chamfer dimension
chamfer dimension
chamfer dimension
How to add dimension to chamfer in autocad19 ? It seems there is no options to do so.
imadHabash
it's supposed to look like below .. you may need to wide your command line space .
Command: CHAMFER
(TRIM mode) Current chamfer Dist1 = 0.0000, Dist2 = 0.0000
Select first line or [Undo/Polyline/Distance/Angle/Trim/mEthod/Multiple]:
Imad Habash
nikm42Q9N
You can use two dimension (one on top length and one on side length) or use the leader command to make an arrow the the chamfer and simply type the dimension . there is no strait forward chamber dimension tool unless your using Autocad mechanical then its in the chamfer command options on the command line
Thank you for your reply.
This is not what i want.Maybe i am not clear enough. I mean to say that
after chamfering , how to add dimension to it using dimension lines...?
Kent1Cooper
@Anonymous wrote:
.... I mean to say that
If you want to dimension along the length of and at the angled direction of the chamfered corner, use DIMALIGNED.
Kent Cooper, AIA
nikm42Q9N
click the dimension drop down click liner dimension and pick two points (auto cad has no auto dimensions) like inventor or solid works so you have to do it manually.
Kent1Cooper
It does have at least semi-automated Dimensioning, in which you don't  need to pick two points when you want just the length of something obvious like a Line or a Polyline line segment.  Use the <select object> option that you get by hitting Enter at the first-extension-line-origin prompt, and you can pick the chamfered corner once, anywhere on it, whether it's from Chamfering two Lines or the corner of a Polyline:
Kent Cooper, AIA
