Cant substract Helix from Cylinder
tanielserrano
tanielserrano
Community Visitor
Community Visitor
Hi, I'm having an issue where I'm unable to substract a helix from a cylinder, I've already checked that both my shapes are solids.
leeminardi
As you can see below the helix is composed of a very large number of facets.  The Boolean computation is extremely compute intensive.
Try subtracting a solid helix of one or two turns from a shorter cylinder then array the results for the length you need.
I would also encourage you to consider applying a texture map to a cylinder that would give the appearance of a threaded rod without the geometry overhead of the approach you are taking.
lee.minardi
